Mirror Wiring
Im thinking of swapping mirrors to the turn signals. whats the wiring ordeal look like.. Just plug and go or do I have to run wires....
Where to get them. I know look around used but running out of patience thinking about going to ford and getting them....... |
Same question mine driver side just got broken off...
This might be helpful, it's a sticky from the exterior section of the forum. 08-10 Tow mirror install
Was about to say..use La Search button!..i made the write up awhile back..most colours are 100% universal
i just did this, i found the power for the clearance lights behind headlamp switch. found the power for turn signals in a taped wire bundle coming from the top of steering column
So your 08-010 writeup should be the same for 04-09 mirrors. got it.
Where to get them not used... and not from ford perferrably |
i only trust ford products, i found some in near mint shape for cheap.. used is OK
