Too much Oil? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-17-2010, 02:33 PM Thread Starter
chrispaine's Avatar
Too much Oil?
Well I just changed my oil and started it for a few min, let it sit for 5 min and checked the oil... it is just over the cross-hatched area of the dipstick. I know not to overfill but would this little amount ever do anything? I am guessing no but I figured I would ask.
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #2 of 11 Old 04-17-2010, 02:47 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
I usually check my oil in the morning before its started for the first time that day. It usually is slightly above the cross hatch area, when I check it after its been run and let sit 10 -15 minutes ,it will read a little low. I put in the exact amount plus a new filter so I know that the amount is correct. If your over after its been run , you have too much oil . I have a Fumoto drain valve on my pan so I can start and stop the oil drain ,if its over filled. It may not be a big deal to be a little over but I'll leave that comment up to other org. members
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #3 of 11 Old 04-17-2010, 03:24 PM
btw check your oil hot.
Dietoremain is offline
post #4 of 11 Old 04-17-2010, 04:05 PM Thread Starter
chrispaine's Avatar
if you check it hot then it would be ok to be a little over cold... ha I'm making a simple thing hard!
On the way--
post #5 of 11 Old 04-17-2010, 06:17 PM
let it run for a little bit so the temp gets up. then shut it down and check it. if you check it cold it will show over full. best reading is after it has been run for a bit.
2000 F250 SD ex cab long bed
6spd trans
south bend 350hp-750lb/ft clutch
6 in lift with 37in Km2 BFG
4in mbrp turbo back single exhaust
TS 6 Pos Chip
DIY intake
SOON TO COME
new injectors
some sort of turbo upgrade
Sullie250 is offline
post #6 of 11 Old 04-17-2010, 06:32 PM
Not sure if it hurts anything but I have run mine a little over and it seems to be just fine.
2001 F-250 7.3L
6-speed manual trans.
D.I.Y. Intake
3.5" straight pipe exhaust
Future Mods
HPX hose
Fuel crossover kit
IBEW Local 343 member
01clj is offline
post #7 of 11 Old 04-18-2010, 07:48 AM
zpd307's Avatar
it will just consume the extra oil, probably through the cdr.
hello, my name is gary
new: 2008 f250 lariat 4x4 ccsb 6.4.....
sold,2011 f250 xlt 4x4 crewcab 6.2 shortbox 5 star tuned
sold,early, 09/98, 1999 f350 lariat 4x4 crewcab 7.3 dually
sold, 1990 f350 lariat 4x4 crewcab 7.3 longbox.
sold, 2003 f350 lariat 4x4 crewcab 6.0 longbox.
1987 we4 turbo buick
2008 taurus limited
zpd307 is offline
post #8 of 11 Old 04-18-2010, 11:47 AM Thread Starter
chrispaine's Avatar
What I figured would happen, just consume the oil that it doesn't need.. What's CDR stand for?
I might go under it again today and drain a little out... Man I have to get one of the drain valves, any places cheaper then others to get the Fumoto valves? For some reason I worry about someone seeing the valve and opening it in a parking lot or something but that sounds stupid to worry about that unless used oil starts being worth cash like catalytic converters ha.
On the way--
post #9 of 11 Old 04-18-2010, 08:07 PM
zpd307's Avatar
maybe its just an idi term, crankcase decompression regulator, its the thing on your driver side valve cover. it allows the blowby gases to escape the crankcase, the tube leads back to the intake to be reburned. some oil mist escapes, thats why your turbo, intercooler tubes and intercooler get oily. which is why some do a road draft tube.
2008 taurus limited
zpd307 is offline
post #10 of 11 Old 04-19-2010, 08:13 AM Thread Starter
chrispaine's Avatar
I was thinking crank case vent. After work i'll drive it home (25min ride) so it will me warm and let it sit for 10min and check. That sounds like a good reading! Thanks.
On the way--
