Transmission Service Question - Ford Powerstroke Diesel Forum
Old 04-15-2010, 06:55 PM
SJB SJB is offline
I have a 2002 F250, and I just had a shop do a transmission flush on my truck this weekend. Total cost was about $120, and I think they just used standard tranny fluid, and I think added in some stuff called Lube Guard.
So I was talking to a co-worker who has a stock 2004 Powerstroke. I was talking to him about a tranny service and he was telling me his service is like $250 because his takes "special fluid and additives". He is basically saying his requires it, not that he just runs the expensive fluid.
I thought that my tranny and his were supposed to be pretty similar, but I could be wrong. So my question is, did my transmission not get sufficient service or is somebody feeding him a line of bull and really overcharging him?
Old 04-15-2010, 07:12 PM
Send a message via MSN to dusted4eva
Well if he is getting a full 17-20 quarts of synthetic then that sounds correct for time and product.
Old 04-16-2010, 03:47 AM
SJB SJB is offline
I understand that, but I don't think that is the case in this situation. This doesn't sound like a case where he just prefers or chooses to run the high $$$ stuff. He was saying his "requires special fluid" with special additives, and none of the local tranny shops will do it. So he "has" to take it to the dealer to have it done. Somehow, I don't think the dealer is really installing high dollar fluid like Amsoil or others. It just sounds a little odd to me.
Old 04-16-2010, 05:33 AM
He doesn't need special fluid. It's all Ford Mercon if he is going to the dealer. So he is pulling your leg big time.
Old 04-16-2010, 05:47 AM
He has a different trans than you. His does technically take the expensive fluid but I know of several people running regular ATF and it works just fine.
Old 04-16-2010, 05:52 AM
SJB SJB is offline
He seriously "believes" his takes special fluid. He isn't pulling my leg. Someone is pulling his, and apparently he believes it. I didn't believe that there was really anything different required between our two trannies. So if he wants to go and pay $250 for probably the same service that I paid $120, then more power to him.
Old 04-16-2010, 05:54 AM
SJB SJB is offline
What fluid does his require? Does it just recommend the synthetic of the same type of fluid that mine recommends?
Old 04-16-2010, 05:56 AM
Look in his service manual and look in yours. They technically require 2 different fluids. You have a 4r100 and he has a 5r110
Old 04-16-2010, 06:00 AM
I think it's mercon sp but I don't remember for sure and when I was looking for it, it was a dealer only item
Old 04-16-2010, 06:03 AM
SJB SJB is offline
Thanks for the info. I was just curious. I didn't realize that our trannies were different. I thought they were still the same 4R100. So I was just wondering if my tranny service was done wrong.
