towing everyday in the summer question - Ford Powerstroke Diesel Forum
Old 04-14-2010, 07:44 AM
I live/work on a peach farm in the summer and I will be towing peach trailers with my 02 f250 7.3 everyday, and multiple trailers per day. These trailers can weigh between 5,000-7,000lbs fully loaded. Most of the trips are short 5-10 miles. My question is, should I turn my overdrive off when towing the trailers to prevent the tranny from getting hurt? My truck is stock by the way, any info would be appreciated thanks
Old 04-14-2010, 11:51 AM
if it keeps shifting in and out of o/d yes. i tow my 2 horse trailer in od no probs. btw. get a better tranny cooler and you'll be fine.
Old 04-14-2010, 11:54 AM
thats ALOT of peaches
Old 04-14-2010, 12:52 PM
Send a message via AIM to 1tonpower
id say anything under 40 keep the OD off
Old 04-14-2010, 02:43 PM
Old 04-14-2010, 02:50 PM
Yes, keep it off esp if you are driving through a town... what you dont want is it shifting in and out of od... once you get going at 40ish the tc locks, then it will fall into od. And if you are planning to drive under 50ish keep the od off
Old 04-14-2010, 07:04 PM
when i had auto trucks i would always turn O/D off. i have talked to some tranny guys and they said the number one cause of a blown tranny behind a stroke was because it was left in o/d tryin to pull a hill with alot of weight
Old 04-15-2010, 12:36 PM
get a bigger trans cooler for sure! you only need to lock out OD if its hunting in and out of OD. I pull my 12k 5er in od and it only jumps in and out if I can not stay above 1700 rpm or so. if I can keep it at 2k rpm Ill push right along at 67 mph and its almost like nothing is there
Old 04-16-2010, 07:15 AM
thanks for the info guys, I will be going under 40mph the whole time so I will keep the O/D off. We had a 04 f150 on the farm and in 2 summers the tranny was shot, most likely because it was in O/D the whole time while hauling the trailers.
