need tool to remove fuel lines - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-12-2010, 05:05 PM Thread Starter
I'm trying to remove my fuel tank on my 2001 psd to replace the bag/filter inside that i believe is causing trash build up in my filter housing. I've got the tank dropped just can't get the fuel lines disconnected. I went to autozone and bought a ford fuel line removal tool but it doesn't seem to work, almost like its to thick. Does anybody know of a different tool or maybe a part no. so i get the right one? Can i get one from ford? Any tips or help would be appreciated, i know its simple with the right tool.
ptjeep is offline
post #2 of 10 Old 04-12-2010, 09:41 PM
mil-specrestro's Avatar
Harbor Freight...was like $9 for a set of 4 different color ones. Worked on the fuel and the AC lines. They are round with a split on one side and a very thin lip. The lip goes into the o-ring area and it opened very easy. Hope this helps.
mil-specrestro is offline
post #3 of 10 Old 04-12-2010, 09:46 PM
nccatfan's Avatar
Send a message via AIM to nccatfan
Recently had a very hard time pulling one of those fittings apart when my fuel supply/return tube assemble started leaking. Turns out it just had a lot of trash built up inside the fitting. Had to poke at mine for a while before it came apart!
-'99 F250 7.3L PSD 4x4 (SCLB, 6-speed)
-'14 F150 4x4 5.0 CCSB
-'83 Ranger 4X4 5.0
nccatfan is offline
post #4 of 10 Old 04-12-2010, 10:05 PM
zpd307's Avatar
they can be a bear sometimes. just remember, use the force......luke.
hello, my name is gary
new: 2008 f250 lariat 4x4 ccsb 6.4.....
sold,2011 f250 xlt 4x4 crewcab 6.2 shortbox 5 star tuned
sold,early, 09/98, 1999 f350 lariat 4x4 crewcab 7.3 dually
sold, 1990 f350 lariat 4x4 crewcab 7.3 longbox.
sold, 2003 f350 lariat 4x4 crewcab 6.0 longbox.
1987 we4 turbo buick
2008 taurus limited
zpd307 is offline
post #5 of 10 Old 04-12-2010, 10:19 PM
nccatfan's Avatar
Coulda swore I was about to go Jedi on mine! Haha!!
-'83 Ranger 4X4 5.0
nccatfan is offline
post #6 of 10 Old 04-12-2010, 10:23 PM
Soot_Life's Avatar
Fords are a paint using the normal parts store Metal Scissor style ones
Oddly enuff the tool you get from GM looks like a CHEAP plastic baby road cone and it works awesome.
force will work sometimes, but honestly pushed in right it should just come right off.
97 supercab 4x4: work truck. Reallly Loud stereo (16 speakers, none visable), 20's/35s, 6637, straight piped.
99vette: stock.
89crx, working on a idea that involves a 454 bigblock, 2.5tons, and boggers.
Custom built 12' jon boat: yea its got a 50 horse jet drive.
Soot_Life is offline
post #7 of 10 Old 04-12-2010, 10:29 PM
Coal Rolling = Posing
The 7 dollar cheap tool worked fine on mine, just make sure you're forcing the tool into the fitting and the fitting on to the tool and simultaniously pulling the whole gaggle away from the line.
chvyrkr is offline
post #8 of 10 Old 04-13-2010, 12:41 AM
zpd307's Avatar
yep, i swear i have willed stuff apart more than actual brute force. just that last little bit of will power..... aka "the force"
2008 taurus limited
zpd307 is offline
post #9 of 10 Old 04-13-2010, 04:31 PM Thread Starter
Thanks for the info, i bought the metal scissor type first and it was to big, it fit in the fitting but wouldn't disconnect it no matter how hard i pulled. Called a friend who had the small plastic ones, clipped them on and the lines practically fell off. It was almost to easy, so i'll be taking mine back and buying some like he has! Thanks again.
ptjeep is offline
post #10 of 10 Old 04-15-2010, 11:06 AM
Soot_Life's Avatar
sometimes you dont get a better tool for paying more
99vette: stock.
