Got some readings from a scanner today.. - Ford Powerstroke Diesel Forum
Old 04-12-2010, 01:53 PM
Got my buddy to take some readings using his scanner today heres what i found out
Pull 2 codes at WOT
P0238 turbo boost sensor a circuit high input
P1211 icp high or low
ICP readings at WOT
Duty cycle 65.1%
pressure 13.36 mpa 17 when i let off of WOT
pressure V - 2.53v
manifold guage pressure at WOT 170kpa
whats all this mean? weak HPOP?
what else should i check?
Old 04-12-2010, 02:00 PM
1 megapascal = 145.037738 pound-force/square inch (PSI)
13.36 x 145.038 = 1900psi ;(
Old 04-12-2010, 02:22 PM
where is the icp and ipr sensor located? could the sensors be bad how do i check?
Old 04-12-2010, 02:26 PM
mpa=millipascals
Mpa=megapascals
Old 04-12-2010, 02:41 PM
well is 1900psi the right conversion??
Old 04-13-2010, 05:20 AM
any takers? id figured you guys would be all over this..
Old 04-13-2010, 05:29 AM
out of the 2 cost effective options out there im considering an adrenaline or a terminator modded 17* any opinions on these?
Old 04-13-2010, 06:47 AM
talked to a buddy over at international he said it could be leaky injector o rings as well
Old 04-13-2010, 07:14 AM
Talked to bill over at dieselsite about the adrenaline he mentioned that there may be a tuning issue since I'm only showing a 65% duty cycle. 65 is the limit set by stock programing but I'm running the TW 100hp performance setting.
Old 04-13-2010, 09:05 AM
Called Tony waiting for a reply. I also unpluged the icp and went for a drive. The truck runs exactly the same. And by the same I mean it runs good just think it should have more on the top end.
