speedo problem
hey guys, picked up and early 99 a couple days ago and on the ride home i noticed that the speedo only works when im doing over 60 km/h. and between 60 and 40 it bounces around sometimes?? any ideas whats causing this??? do i just need a new speedo cable or a new sensor??
It is probably the Vehicle Speed Sensor in the rear axle housing. It is mounted in the center / top of the housing with 2 wires going to it. Takes 5 min. to replace. To be sure if it bad, run the codes on it, the should be one for the VSS.
dont got a code reader, how much is the sensor worth ??
It isn't an expensive part, but try cleaning it first. Fixed mine.
I think mine was $15-20.
Mine just started doing this. Was reading 70 then dropped down to 60 then back up to 70. No check engine light showing so I wouldn't think it had codes in it.
just repalced mine, Ford $26
Easy to replace. If is isn't the sensor, it will go soon enough if you are doing any kind of driving that isn't on a perfect smooth road (I haven't found such a road in America yet).
JMTC |
