Truck has been vibrating under throttle. HELP
i don't know if its coincidence but after i put a new rear main seal in i noticed vibration while driving. starts between 40 and 50 mph once im past that it quits. sometimes vibrates in coming out a stop and turning. since there is no vibe when im parked and just revving it i feel like its safe to rule out any motor problems but i could be wrong.
in search of the problem i ended up putting in warn hubs because i thought that was it.. not the case, still get the vibe. all new u joints and carrier bearing, still vibes. i am stumped... some other possibilities i have considered are the flex plate being warped or a spring being broken, but the trans is fairly new. also i noticed a plastic ring on the back side of the hub is just dangling on the axle... wtf i tried to be very specific as to what is happening. please help if you can! |
Vibs: I was going to suggest everything you have already done. You didn't leave a shim out of the carrier bearing support did you? |
dont rule out the motor, the tc locks up around 38 mph. Thats when a shake would be felt if its the motor.
also check the front wheel bearings, inner and outer. see if u can lift the axle shaft on each side in the front. if you can move it alot the inner bearings are out on that side
i had a shop do the carrier bearing so i don't know about the shim. what do i need to do to check?
i have considered the tc... the vibe is always under throttle, once i let of the gas it dies out slowly and is gone??? |
It doesn't appear you truck is lifted. If so you wouls expect to see 1/4" +/- of shim for every inch of lift. If no lift then this is probably not your problem. I would look at the bolts and see if the nuts are in the same relationship as before. No "new" bolt threads exposed.
HANK
leveled in the front and converted rear springs to one ton, but the vibe was there before i did that. can you be clearer on what you mean by the bolt thing???? Last edited by lcducote; 04-11-2010 at 07:50 PM. |
could it be an injector not working properly?
you got me stumped..... you done everything i would have suggested also.
anything about it being the injector?
