Need Help Identifying Gear Ratio - Ford Powerstroke Diesel Forum
Old 04-10-2010, 07:41 AM
Just bought a new truck, you can see details in my signature.
The rear differential cover looks a bit rusty and I will be replacing it and changing the fluid while I am at it.
The door jam does not have an axle code.
Here is are the two stamps, I need to know if I have a limited slip diff, because I believe I have to had friction modifier in the fluid if I do.
Thanks for looking!
Old 04-11-2010, 05:27 AM
3:73 limited slip if I am not mistaken....there is a 3 under the bolt head on the tag thats on the passenger side of the rear axle.....Fred
