hard brake line info needed - Ford Powerstroke Diesel Forum
Old 04-09-2010, 07:43 PM
I accidentally cut one of the rear pass side steel hard lines.(dont ask how)
I measured it its approx 40 inches. I can get line from advance or a parts store. They have the 3/16 line. But all of their lines have the same size fittings on both ends. The end that goes to the junction lock at the flex hose is larger thread. I found metric to not work. I guess the brake caliper side(to rubber hose) is 3/16 american. That seems to be the right size. But the other end is larger. DOes anyone know what size these are? especially the larger side?
thx
Old 04-09-2010, 07:54 PM
I dont know the sizes off my head and Im not a fan of Napa but most of there stores will have the lines and addapters to get you straightened out espically if you find a good worker there and take in your old lines , you will have to get a line with the same size ends then use a fitting that converts to the bigger size. I ended up buying a flange kit and cut the wrong size off and puting the right size on, but either works fine.
Old 04-09-2010, 10:20 PM
I would just go to the junkyard and pick one up. should be able to get it for 5 bucks max.
if you want some nice SS lines and have time to wait. Riffraff Diesel has a great set. Shoot clay an email sales@riffraffdiesel.com
