Doing some maintenance, what else should I look at - Ford Powerstroke Diesel Forum
Old 04-07-2010, 10:09 AM
New Powerstroke owner and a diesel newb in general.
My 2000 f350 has a small oil leak that is running down the back of the motor. From what I understand it is usually the turbo pedestal or the HPOP so I am going to start with those 2 items. While I am working in that area, is there anything else that would be good to checkout/replace while I am in there?
Thanks
Viking
Old 04-07-2010, 04:43 PM
Just an FYI i was told that my oil cooler is leaking. It is coming down behind my oil filter...
Old 04-07-2010, 04:46 PM
Oil cooler on a 7.3? Haven't heard of that before. USUALLY it's the HPOP o rings or pedestal/turbo o rings.
Old 04-07-2010, 04:51 PM
Mines leaking..... If yours is heres some info on it. But two other leaky locations are listed above by jesilvas
Oil Cooler break down - Oil Cooler
Oil Cooler Repair - Ford Powerstroke Diesel Forum
If your clearin a space up on your motor for repair. Take a scrub brush and clean er up. A clean motor is a happy motor. Plus it makes it nice not to get dirty every second you touch a piece on your motor
Old 04-07-2010, 05:00 PM
hmmm. Didn't know they tended to leak
Old 04-09-2010, 05:45 AM
Thanks for the info. I'll check it out.
Viking
Old 04-09-2010, 11:17 AM
oil coolers tend to leak over time..... was common on the idis. the two are pretty much the same.
