First tank of bio-diesel - Ford Powerstroke Diesel Forum
Old 04-26-2007, 08:13 AM
Send a message via Skype™ to ExcursionPSD
Finally did it. After reading about the subject and wrining my fists I took the plunge. We are just getting our first B20 pumps in San Antonio this week so it was a bit hard to find. I decided to buy B100 from a local bio-diesel plant and make my own mix. Added 15 gallons of bio-diesel to 27 gallons of ULSD for about an approximate 34% blend.
I have recently replaced my fuel pump, sending unit and fuel filter so I'm hoping it will be okay to start this high. Whatever I guess since I already did it.
Wish me luck.
Old 04-26-2007, 08:25 AM
SMOKE ROLLER
Good luck and keep us posted on the results...
Old 04-26-2007, 08:26 AM
good luck bro... let us know how it turns out... im very interested in going green in my stroker sometime next year
Send a message via AIM to jngreen
good luck, I like my B20 from my local fuel Co-op
Old 04-26-2007, 08:55 AM
Send a message via MSN to Justinlw
My truck had 79k on it when I filled it up with B100. It plugged the filter once after the second tank of it, and never had a problem after that. Since then I have used about 375 gallons, and only noticed a minor decrease in economy. As long as you use an additive such as power service with petroleum diesel before you switch to Bio, there won't be much tar in the tank to plug your filter. Since most of you guys run additives, you have nothing to worry about. B100 is the way to go in south Texas, because we never have the extreme low temps to worry about.
Old 04-26-2007, 08:58 AM
BTW, you should keep a filter behind the seat just in case.
Old 04-26-2007, 12:05 PM
where in san antonio can you get it?
Old 04-26-2007, 12:37 PM
There is a place here in Austin the makes B20 and B100, Pretty cheep if i remember right..
Old 04-26-2007, 05:19 PM
I got it from Alamo Bio Diesel. Found them on Biodiesel Locations | OVER 1200 VERIFIED LOCATIONS IN THE US
Also Mid Tex Oil Company in New Braunfels has set up 4 pumps in SA with B20. They are the Petro Panty locations.
