Series of Dings - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-01-2010, 07:15 PM Thread Starter
tneibling's Avatar
Series of Dings
After I start up my 99 and just get ready to drive, a dinger similar to the door ajar, dings for several rounds of 5 dings. Then it does the same every so many miles. It seems like it might be some kind of warning but i have no CEL or diagnostic lights on. This started a few weeks ago when i was having brake trouble. I had Ford to the work and it still dings every so often so
My truck:
99.5 F250 4x4 Ex cab long bed
7.3, zf6
Swamps 175/30's
Cales tunes
DIY Intake & Zoodad mod
Muffler Delete
DIY CCV mod
Foil Delete
DIY leveling kit
AIH delete
Autometer Phantom II Boost and Pyro
Luk Clutch
Dad's Truck:
2001 F250 4x4 Ex cab short bed
7.3, 4R100
Muffler Delete
Foil Delete
DIY CCV mod
AIH Delete
DP Tuner F5
tneibling is offline
post #2 of 5 Old 04-01-2010, 07:45 PM
are you wearing your seatbelt?
I'm a wh0re for free stuff
kinghawg98 is offline
post #3 of 5 Old 04-01-2010, 07:46 PM
Zaairman's Avatar
Quoted: 12 Post(s)
I think that means there is a problem with the airbag system.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #4 of 5 Old 04-02-2010, 12:02 PM Thread Starter
tneibling's Avatar
Most of the time I dont wear it if I'm just going to be around close (10 mile radius or so) but I always wear it if I'm goin much farther than that. I did unplug the seatbelt sensor wire under the seat if that might have something to do with it.
If it's dark, the airbag light will very dimly glow for a while.
My truck:
7.3, zf6
Swamps 175/30's
Cales tunes
Muffler Delete
DIY CCV mod
Foil Delete
DIY leveling kit
AIH delete
Luk Clutch
Dad's Truck:
7.3, 4R100
Muffler Delete
Foil Delete
DIY CCV mod
AIH Delete
DP Tuner F5
post #5 of 5 Old 04-02-2010, 01:16 PM
My 2000 does the same thing. On mine it is the e-brake pedal. I pull the release and pull the e-brake back and the dinging stops.
clark7.3 is offline
