To hot? - Ford Powerstroke Diesel Forum
Old 03-31-2010, 02:17 PM
To hot?
Running at 65mph empty I am seeing 800 deg egt temps and about 10 pounds of boost. I have a 4" turbo back and no tunes. Getting around 18 to 20 mpg and power feels ok. I just changes the fuel and air filters. Just want to see if ths is normal. Also trans is about 145 to 150. Is that ok?
Old 03-31-2010, 02:33 PM
all those numbers sound perfectly fine... i wouldnt worry about it
Old 03-31-2010, 02:45 PM
Send a message via AIM to Strokeorcroak Send a message via Yahoo to Strokeorcroak
numbers seem right except for the boost, i've never seen 10lbs of boost going down the highway... Am i mis reading something?
I was thinking less than 5 going down the highway at 65
Old 03-31-2010, 03:00 PM
Maybe a head wind is causing the 10 psi sometimes ?
Old 03-31-2010, 03:06 PM
that could be it, but he says this like its an average of what he is seeing, you wouldnt always have that headwind haha. And at 10psi of boost i wouldnt think you'd be seeing almost 20 MPG?
Old 03-31-2010, 03:22 PM
I just went and go food. I looked again and it's more like 7psi.
Old 03-31-2010, 03:24 PM
I guess that may just be the difference between a SD turbo and a OBS turbo, but i am under 5 when crusing and i can spike it to 35 if i really try
