another gauge question - Ford Powerstroke Diesel Forum
Old 03-31-2010, 01:33 PM
got my pyro,boost and trans in yesterday
my question is i am seeing around 4 psi and 600 degrees at 70 miles/h empty on highway is that normal?
i was seeing higher boost out of my old 6.5
this is a stock truck with a strait pipe and a 6637 filter
i do see around 20 psi at wot
and i know already i need a better trans cooler it was reaching 190 empty in city and highway and around 70 degrees outside
Old 03-31-2010, 01:36 PM
and i know already i need a better trans cooler it was 190 reaching empty in city and highway and around 70 degrees outside
Those numbers are in line with what I see ... The trans temp is too high ... better get a cooler or something else could be wrong ... I hope someone with more knowledge will chime in ...
Old 03-31-2010, 01:52 PM
yes the trans is a little hot but it was just rebuilt and i was in Chicago traffic
boost looks a little low to me
Old 03-31-2010, 01:59 PM
I have not seen higher than about 170* towing 7000lbs in 70*-80* weather and traffic, pulling hills ect ... that tranny temp is borderline bad ... I hope some others will chime in and comment ...
Old 03-31-2010, 03:29 PM
I can get to 170-180 empty when 80 outside, never towed so not sure on loaded temps.
Old 03-31-2010, 03:34 PM
ill call the trans shop in the morning
also ill clean the radiators this week
thanks
Old 03-31-2010, 03:35 PM
is your sender in the pan or test port?
Old 04-12-2010, 09:20 AM
the cooler was part clogged and the sender for the gauge was in pieces when i puled it out lol
i see 150 on the highway 155 in the city today in a 65 degree weather
Old 04-12-2010, 09:02 PM
my tranny gauge should be here on wed, then i can put in my pyro and boost gauge. i am interested to see what is happening. especially since i have an e99 with the crappy cooler. next up is getting a 6.0 cooler.
Old 04-12-2010, 09:57 PM
@70mph I see about 6-8psi boost, and I run about 140-150° trans empty, I have seen 195° when pulling 15000# @ 70+mph.
