boost question?
i drive alot of back roads my trucks got 100hp chip with boost gauge and other gauges i hit low boost like 5-6psi my truck runs awesome and has power what are you guys getting for boost
when I just hammer it flat out I hit 25psi.....5psi is when Im barely in the throttle
how is your boost gauge hooked up. because thats just not correct.
idk its on my edge chip now i didnt get my others in yet
It must not be hooded up correctly or it is just bad. You should ditch the edge anyways they are trash, save yourself a trans or two and get some custom tunes and a good set of gauges.
When i had a edge i could hit 25+ easy. Up to about 28psi max.
is that on back roads with a speed limits of 35mph i get to 40mph sometimes. it hits 25psi on the highway i think also the turbo is after market so could it be just a low boost turbo
Just cruising you should see 2-7 psi, WOT you should see about 22-25
so my truck is doing about that so every thing is working as it should then
Will my edge evo on the 80 hp setting I can push it to 30 psi on an uphill entrance ramp. Crusing at 70 I got about 4 psi and it will climb to 8 or 9 going up hill. Taking off at around 2000 rpm shows about 7-10 psi
