newby here with some questions - Ford Powerstroke Diesel Forum
Old 03-28-2010, 05:28 PM
hey guys and gals newby here also a newby powerstroke owner i have a 99 f-350 and dipstick is puking oil out of it can you change both o'rings without dropping pan any help would be greatly appreciated
Old 03-28-2010, 05:41 PM
Powerstroke Techie
Nope and good luck trying to get the pan off in chassis. Most techs pull the motor to change the oil pan. The pan gasket is gray silicone. If you don't use the right silicone it can leak and you'll have to do it all over. The correct silicone is motorcraft part# TA-31.
