Dumba** attack when changing oil, have a ? - Ford Powerstroke Diesel Forum
Old 03-26-2010, 10:48 AM
Changed the oil in my truck and things didn't go as smoothly as past oil changes had, I basically looked as though I had bathed in diesel oil . While still dwelling on all the crap that had happened earlier I went ahead and poured a total of 16 quarts into the engine, when the manual states 15 as max. Should I attempt to drain a quart from the pan or will the engine be ok running a quart high?
Old 03-26-2010, 10:52 AM
I don't know nuttin....
It will be fine.
Old 03-26-2010, 11:07 AM
Thanks for the quick reply!
Old 03-26-2010, 11:22 AM
If your wanting to take some out, pull the top filter cap off and suck some out with a syringe.
Old 03-26-2010, 11:23 AM
And look into a fumoto ez drain plug for a mess free oil change...
Old 03-26-2010, 11:27 AM
as long as the dipstick isnt to much over, your good to go
Old 03-27-2010, 07:32 AM
you know i have a fumoto and its still messy. the oil filter is what really makes the mess.
Old 03-27-2010, 08:10 AM
I drive an awl into the bottom of the oil filter and let all the oil drain out of it before I remove it. It saves you from the oil running down your arm.
Old 03-27-2010, 09:26 AM
Thats what my wife does when she changes her oil... Yes, my 125# wife changes the oil on her Excursion... And does it with her nails and all.
Poke a hole the the filter with a awl, screwdriver or what not...
Old 03-27-2010, 09:42 AM
i suction most of the oil out, then punch a hole in the filter, and then pull the drainplug. works great, no mess unless it's windy.........
