P0308 - #8 Cyl Misfire Detected - Ford Powerstroke Diesel Forum
Old 03-23-2010, 06:11 PM
I've been having an intermittent SES light so I put my cheap scanner on today and it returned the generic P0308 which I was able to clear with the scanner. I did a search here, seems to point to the #8 long lead injector which is prone to go bad right?
Questions:
Truck is running fine, can't tell there's a problem. How drastic is this? In the search, everybody else had a boatload of other codes including P0284 (balance fault).
Since this is the long lead injector, can a misfire be caused by fuel starvation due to a fuel filter needing to be changed, or a lift pump failing? I admit I've been waiting to change the fuel filter until I can get some biodiesel in it, but the local biod supplier is shut down. This filter was on the truck when I bought it, PO was deceased, so I have no idea how many miles are on it.
Diagnosing lift pump issues?
I plan on doing a regulated return, partly because it is supposed to help with fuel starvation in #8. If I remember right, once you do a regulated return, you can use a regular injector rather than the long lead on #8, so should I just wait and do the regulated return?
Ramble ramble--- thanks.
H
Old 03-24-2010, 07:22 AM
Powerstroke Junkie
I would have someone run a buzz test.
