HPOP fill on oil change - Page 3 - Ford Powerstroke Diesel Forum
post #21 of 44 Old 03-22-2010, 05:00 AM
Powerstroke Junkie
NCHornet's Avatar
Originally Posted by carolinaboy02powerstroke View Post
might want to just take a look around this site...this guy will answer most any question you have!
POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners
That dude is a IDIOT!!! Anyone that actually recommends the K&N for a PSD is a IDIOT, through and through. This HPOP oil change is the biggest joke to hit the world wide web in a long time. I bet your parents bought Pet Rocks in the 70's didn't they? If you would take the time to learn how the oil system works you would never post that you are changing your HPOP oil!!
Funny I have seen plenty of 7.3's over 500K and one that will be over 900K in the next month and guess what?? They never changed their HPOP oil!! Because they understand it is being replaced every few minutes anyway!! As far as the heads go, you can't change that oil, that is why they brought it up!
I have done this one to many times before. Do what makes you feel all warm and fuzzy inside!!
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #22 of 44 Old 03-22-2010, 06:27 AM
O.I.F. Combat Vet 11B
It literally takes me no more time to do it since I can suck it out while the oil is draining out the pan. so why not go ahead and get as much of the old oil out as possible............. Can't see where it would hurt and since it only has to be changed for me like twice a year I will continue to do it.
2000 f250 crew cab 4x4 6sp manual, Jim Rosewood 238/100 hybrids, gtp 38r, srp1.1 hpop, DP-Tuner! Driven diesel fuel sys!
269,xxx and counting!!
ju015dd is offline
post #23 of 44 Old 03-22-2010, 08:49 AM
Powerstroke Junkie
NCHornet's Avatar
Wait until you get air trapped in there and see how much fun it is to get it started when you're done!!! Like I said if it makes you feel good, who am I to say it is a waste of time, lol!!! Certainly not me!!!
NCH
Ford AIS/ BTM, FTVB
KMC Wheels x 4
NCHornet is offline
post #24 of 44 Old 03-22-2010, 10:12 AM
We just went through that with a friends truck. Somebody told him he needs to change it so he sucked it all out. anf filled it back up. Somewhere in the process it got air in the system. 6 hours and a new starter later the truck is running again. Huge PITA
2000_f350 is offline
post #25 of 44 Old 03-22-2010, 06:42 PM
BGJ
BGJ's Avatar
We just went through that with a friends truck. Somebody told him he needs to change it so he sucked it all out. anf filled it back up. Somewhere in the process it got air in the system. 6 hours and a new starter later the truck is running again. Huge PITA[/QUOTE]
Good to know, this is the first REAL negative thing I've read about doing this.
Thanks for the post.
BGJ
BGJ is offline
post #26 of 44 Old 03-22-2010, 06:46 PM
Same here, you would think that when you fill it back up with new oil it would push out any air in there. something just doesn't sound right...
ju015dd is offline
post #27 of 44 Old 03-22-2010, 07:00 PM
BGJ
BGJ's Avatar
I'm with ya, how many times have you sucked it out & refilled it? I know on dirt bike radiators, you fill through the cap on the right one & there is a screw that you take out on the left one so you get all of the air out. I can see where not having a second hole on the HPOP for air to escape you might have an air lock issue. Most of the guys here are very helpful, some enjoy bashing a bit though.
Take car, I appreciate all of your posts.
BGJ
02 F250 Leveling kit, 295/70/17 Nitto Terra's
39501 miles on the clock
BGJ is offline
post #28 of 44 Old 03-23-2010, 06:00 AM
Powerstroke Junkie
NCHornet's Avatar
I am not BSing ya!!!
NCH
Ford AIS/ BTM, FTVB
KMC Wheels x 4
NCHornet is offline
post #29 of 44 Old 03-23-2010, 06:20 AM
catlinB's Avatar
NCH
isn't the intention of doing an "oil change" to take out all the dirty old oil???
thats what we were taught in Automotive Repair.
Also i have the Ford manual in front of me, its an older one updated in 97 for the 7.3 powerstroke motor's , its right from ford, i got it from a mechanic who works there, and it recommends the HPOP res should be drained at time of oil change and replaced with new oil for risk of contamination of the new oil.....
so thats what Ford tells there Techs. i think i'll do what the experts say
Catlin...
newest
2002 F-350 Lariat Ext Cab
4x4 auto, 139,000miles
with a super-chip tuner
SOLD
2000 F-250 Lariat Ext Cab
4x4 6 spd
Stock
1996
F-250 4x4 7.3L Turbo(Stock
5 speed ZF
3" Body Lift
Originally Posted by JJFLASH View Post
Lol what kind of frankenstroke did you buy???
catlinB is offline
post #30 of 44 Old 03-23-2010, 06:45 AM
You can pour oil into either hole on top of the reservoir, and they both go to the same place. You really can't get an air bubble into it. You really don't even need to fill the reservoir before you try to start the truck if you have drained it. I do, because usually when I have drained it, it is because I have pulled the high pressure pump, injectors, drained the rails, etc. It makes sense to fill it back up to make the start up quicker.
I've done it without filling first. The truck takes about 30-40 seconds of cranking before it will re-prime the oil rails.
For a truck that is just getting a reservoir oil change, there should be absolutely no problem just cranking it with dry reservoir. The low pressure pump has such a massive volume that it will fill the reservoir before the high pressure pump even starves for oil.
If you don't believe me, start the truck without the fill plug in the reservoir, and see the oil fountain. It will be huge. It will fill the reservoir in a second or two.
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
