ICP Sensor failure signs?
What are some signs of the ICP sensor going bad?
rough idle.....unplug it see if that helps...if you unplg it and it runs better replace it
I've read on here that oil saturation on the pigtail connector is a sign you will have problems soon.
If it goes out it will leave you stranded won't start. Replace sensor and pigtail, make sure you use the protective heat shield that is on the connector.
sorry for my studipity but what is the icp sensorand where is it located
If the sensor is bad will it cause the SES light to come on and stay on? Also could it possibly cause my truck to not smoke as much at times? My truck will smoke alot of black sometimes and other times it just dont as much.
The ICP is the fuel pressure control sensor it is located on the top of the left (drivers side) head, it is easy to get to on the 7.3, I just replaced mine because it was starting to get oil in thr connection, it was $163.00 + tax at the international parts supplier.....Fred
BUMP>>>>>>
Those lil buggers are not cheap.
Ya I know. Im just wanting to know if the SES light comes on when its bad and if it is bad can it cause the truck to not smoke as much black sometimes?
