Superlift Truspeed help - Ford Powerstroke Diesel Forum
Old 04-19-2007, 02:02 PM
Hey guys, this is my first post here so bare with me if this is in the wrong section. I just got my Truspeed in and was trying to find the ABS controller. Do you guys know where I could locate this to tap into it? I have a 2000 F250, 4.56 gears, 42" Irok's, etc. If you need any more info I will get it to ya.
Thanks for your help,
Matt
Old 04-19-2007, 07:35 PM
Bump to the top since I am thinking about gettin one. You gotta come back and let us know how you like it when you get it right.
Old 04-19-2007, 10:04 PM
I just bought the truck two weeks ago, so I will definitely be frequenting this forum! Hope to get the Truspeed installed this weekend if I can find this wire.
Old 04-21-2007, 06:41 AM
I installed one on my '99 a few years back and I tapped into the signal wire (the Truspeed is in series with this wire) which for mine was under the air filter/battery tray on the drivers side. This is where the harness is located for the brakes, etc. I calibrated mine with a GPS handheld unit for true groundspeed. It is too hard to get it right by trying to follow someone, etc. I can try and find my info on the exact wire if you need it.
Old 04-21-2007, 10:57 AM
heres the best link
Superlift TruSpeed ratio converter
go threw the wheel well there is a few screws to remove but it is real easy
Old 04-21-2007, 01:40 PM
THANK YOU fleastang and MidwestOffroad that was just the info I was looking for. That link should make this install go very smoothly. I'll be back in a few to give a report back on how things go!
Thanks again guys!
Matt
Old 04-21-2007, 06:01 PM
when you fine tuning it with a GPS , The GPS will take a about a mile to be up to catch up. so crank the screw a 1/4 turn at a time and wait a mile and re adjust.
Old 08-17-2007, 12:00 PM
Does anyone know if these instructions will work on an '05 too???
Old 08-19-2007, 10:25 AM
Yes they will.
Old 08-19-2007, 10:41 AM
who needs a correct speedometer just put go with the flow. thats what i do. lol
