Where to install superlift speedo correction device?
I have 315/75/r16 BFG A/T on my truck. I was lucky enough to get a TW chip for Christmas. It seems to have changed the shift points (which is great) but I noticed it won;t shift into the highest gear until 45mph. I am also not 100% sure of my MPG since the tires have the speedo and trip off.
i know it is off since I was pulled over in VA and I had to get the truck calibrated by a professional speed shop (they do the VA state trooper cars speedos) to prove that my speed said I was doing 60mph (even though the truck was actually going 66mph). It is off by that much!!!! I was able to get a brand new speed recalibration kit from Superlift off a buddy who never used it on his truck. It actually can be set for two different size tires (incase you change size for the winter vs. summer you can just flip a switch). Finally my question...where do I hook this up at? Before the ABS sensor, after it etc... so the truck know properly when to shift according to the TW chip and also still be able to read the correct speed on the dash? Wow...that was confusing to write!! Does it make sense?
Did you tell TW your tire changes?
Factory service dept can recalibrate your PCM for the tires, take out the chip first. |
Best place to install it... Is to not...
Call up ITP or Powerhungry performance and get Auto Enginuity... for $350 bucks you can set your speedo to any tire size you want up to 40", and have the ability to do your buddys trucks, scan and clear codes, run all the tests the ford shop can do... Take that Superlift crap and send it back... |
The wire is located under your battery trey. I can't remember the color of the wire. But as Caryt says Ford can recalibrate it for you. Or you can spend about 330 bucks and get AE and calibrate it as many times as you want.
then have a really nice diagnostic tool!
Yes I did tell him the tire size difference. I have a late 99 and I know the speedo is still off b/c i can compare it to the GPS to get an idea (6mph is a big difference).
Any more Help would be appreciated. |
It is on the drivers side. I can't remember the color. see if you can find the instructions online. I will see what I can find as well.
Just did a quick google... It is gry/blk and here are the instructions. Make sure you solder the connections!!!!!!
http://www.superlift.com/instructions/33001.pdf |
Thank-you layson.
people like you are the reason I like this .org |
Well I will do with it. I hope you are wrong (but most people on this org aren't). If your "sorry" was sincere, then thanks (I did note the sarcasm).
