EGTs when towing???? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-19-2007, 05:42 AM Thread Starter
Fishing Fanatic
kefier2001's Avatar
OK I am moving (transferring) to Maine tomorrow, and it will be the first long distance tow with my truck. I am pullin a 27 ft boat on a tandem axle trailer weight approx 6500-7000 lbs. What is the ok/normal EGTs for me to be CONSTANT at. I know during acceleration, they will get up there for a few secs, but what about constant temps. I just want to know how hard I can push it and not hurt anything. Thanks guys!!
2001 Ford F-350 Crew Cab 4X4
7.3L w/Built-up A/T w/billet Torque Conv.
4 inch SkyJacker lift w/35 inch AT's on Weld Wheels
Diablo Sport Predator Programmer
40,60,85, and tires gone!!(100hp)
4inch Farmboy Exhaust (No Muffler
), 10K Mod, Dfuser TC Lock-up Mod,
AIH and EBPV delete, MAP fooler,Glow Shift Gauges (EGT, Boost, Tranny)
Zoodad and Tymar DIY intake, CCV re-routed
More to come
kefier2001 is offline
post #2 of 14 Old 04-19-2007, 06:35 AM
when i hauled a 20 foot gooseneck full of cattle from oklahoma to iowa i ran about 900-1000 with spikes up to 1200
but i was using the edge juice w/attitude so that automaticaly backs down at 1050 to keep the egts in the safe
itsfred804 is offline
post #3 of 14 Old 04-19-2007, 06:42 AM
bryanbrown's Avatar
loaded heavy, I'm at about 1000 at 75, and it gets up to 1300 when on it hard up a hill. You shouldn't have any problem driving as hard (and fast) as you want
'01 F350 2wd Lariat Dually 7.3 6sp-back to stock
'06 Dodge 4wd Dually, Auto, Edge Juice, AFE Bladerunner, 5" turbo back, BHAF
****SELLING ALL MY STUFF**NEARLY ALL GONE**PM IF INTERESTED IN ANYTHING***
Spearco 6.0 Retrofit I.C.- $800 shipped
coated uppipes(not bellowed)- $200 shipped
bryanbrown is offline
post #4 of 14 Old 04-19-2007, 08:02 AM Thread Starter
Fishing Fanatic
kefier2001's Avatar
Thanks for the input guys. I appreciate it.
More to come
post #5 of 14 Old 04-19-2007, 09:49 AM
dragr8cer's Avatar
I agree, when I am pulling my 34ft. enclosed trailer, with my TS on 50 hp I see about 900 on the flats at 75mph to 1100 up the hills. You should have no problem at all.
TS 6-position chip, wicked wheel, 6637 mod, Warn hubs, Sonnax valve and Tricumulator springs, straight pipe, ion wheels, High pressure Oil crossover, ATI tripple disk torque converter, John Wood valvebody.
dragr8cer is offline
post #6 of 14 Old 04-19-2007, 10:00 AM
to answer that question, you dont want to be hotter than 1200 to 1300 fir extended amounts of time, or things start to melt....
02 F350 PSD Lariat CC
mostly stock except the bb turbo and stage 1's...
...and of course the supporting mod's
Dagnuten is offline
post #7 of 14 Old 04-19-2007, 10:30 AM Thread Starter
Fishing Fanatic
kefier2001's Avatar
Knew about not staying at 1250 and up for a period of time, just concerned about running at 900-1000 consistently. Thanks guys!! See ya on the other end of the east coast. Florida to Maine, go figure!!
More to come
post #8 of 14 Old 04-19-2007, 11:16 AM
duct tape & zip ties
bigcountrysg's Avatar
Hope you have a safe trip and enjoy the scenery on the drive. Your gonna have to get use to the weather change though.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #9 of 14 Old 04-19-2007, 11:41 AM
International Threat
Marty's Avatar
You can tow all day long at just below 1250... do you want to? No because you're likely getting poor fuel mileage. That 7,000lbs IS NOT much at all. I towed that from MD down past Tampa Bay a few months ago. I forget what my EGT's were but even on long hills I didn't go above 1000 then again I never went over 70 mph except to pass a tractor trailer.
If you go thru Maryland (on 95 like I'm sure you will) and you have ANY problems don't hesitate to call!
443 553 9234.
I know of 2 other people that are along 95 too that might be able to help if something goes wrong!
If you've kept up to date w/ your maintainence then you should be FINE! You're doing what these things were MADE FOR!
I just changed my oil, and I would take off across country right now if I had to... that's how much trust I have in my truck. In the past 2 years it's only left me stranded once... it blew an o-ring which costs a few pennies to replace. My fault... I could have avoided it but I had to drive it until it died.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #10 of 14 Old 04-19-2007, 12:25 PM
slammedSI's Avatar
same here, Towed a 25 foot car hauler and a 95 crown vic a few months ago from south texas to OK, combined weight of 9000lbs and only hit 1100 once to pass some one on a hill. stayed at 850 most of the way, but texas is really flat so that makes a difference.
-Bobby Crews- AKA Dr. Cookie Cutter!
2012 Ford F150 Ecoboost
-STOCK-
A 7.3 with an edge should never get into a race. Unless it's with a kid on a bicycle.. and the bike has a flat.
slammedSI is offline
