a dumb question to ask - Ford Powerstroke Diesel Forum
Old 03-06-2010, 08:01 AM
Is there a timing belt in 7.3 engine?
Old 03-06-2010, 08:17 AM
i don't know specifically if there is a "belt", but something would have to open/close the valves at the right time. there is also a position sensor that tells the computer what position the engine is in, so the computer can deliver the fuel at the right time.
Old 03-06-2010, 08:49 AM
no timing belt... Timing is meshed off the crank and cam... All under the front cover... See if I can find a pic...
Old 03-06-2010, 09:00 AM
BGJ BGJ is offline
Cool pic. Here's a Q for you. Is it cost effective to rebuild the 2002 7.3. I was told otherwise. Can you buy remanufactured 7.3's at a good price or better to buy new. Thanks BGJ
Old 03-06-2010, 09:05 AM
With 20k on your truck why are you even thinking of a rebuild?
A rebuild kit from IH is only about $1300 or so, maybe $1000 in labor work on the block and heads and your in it about $3000 after parts and gaskets...
Old 03-06-2010, 09:31 AM
BGJ BGJ is offline
Thanks, Just cause this "Know it all guy" told me that these engines are throw aways when they finally wear out. Thanks
Old 03-06-2010, 04:57 PM
and theres some seen that tow daily that have over 1,000,000 miles why? lol
Old 03-06-2010, 05:05 PM
They can be had for cheap already rebuilt but you will still pay more then you would if you did it yourself
Old 03-06-2010, 05:38 PM
horsepowershop.com look at black mamba
Old 03-23-2010, 07:09 PM
so Ryan, are you in the left, or right skidder in the pic??
