injector brass washer - Ford Powerstroke Diesel Forum
Old 03-06-2010, 02:46 AM
The injector brass washer, do you put that on the injector first then insatll the injector? Do you put it i the head then stick the injector in? I put an injector in from beans last nite. It went in attached to the injector, i read somewhere that said put the washer in the hole first? Mine seemed to be stuck on the injector tight enough. I left it?
cool?
Old 03-06-2010, 06:01 AM
On the injector is correct. It will seat correctly to the head when the injector is tightened-down.
Old 03-06-2010, 07:29 PM
agreed, on the injector, when I do injectors on our tractors I always put a coat of anitseize on, then the washer, and coat the washer, it holds the washer on for install and makes them much easier for removal later.
