DOOR AJAR
Ive seen other peoples post about using wd-40 to try and clean the sensors and all that, which ive tried mulitple times, ive tried everything I know how to, and it will still not go away, anyone know another way of getting rid of this so that my lights wont stay on, and wont beep when I have the key turned back for just the radio, is there a wire I can cut?? Any ideas?? thanks!
It sounds like a lot of guys spray from outside of door latch and will work most of the time-but it sounds like you have a good build up on one of them-remember,these switches point up-so it's easy to gunk them up.
While wd40 will work,I've found silicone spray works better because wd40 is fish oil and stays tacky and catches more gunk,while silicone is a dry spray lube. Some guys even use brake cleaner first-I never had,so I don't know. You really should remove switch from the latch and clean well-I believe the switch has to be open to make lights go off. Hope this helps. |
beat the "F" outta the switch?..haha no really.. clean it with brake clean really well and use a good silicone spray, works like a charm. not like the door panels are hard to get off and remove the latch anyways!
thank ya guys brake clean and silicone spray will be put to the test 2morow!
I would not spray brake cleaner into my locks!
Plastic, glues, and sound deadner don't do well with those solvents, who knows what could be in there ![]() Your swithch could just need to be replaced and no amount of spraying stuff in there is going to fix it. You've already tried that ...... |
Remove the switch, clean it, and then use silicone spray. For my F150 I removed the interior light bulb and my lights wouldn't stay on from this problem.
lol, i like that. I'm having the same problem with my rear driver's side door. Gonna pull the switch out this weekend.
