7.3L differences?????
Ok this is probably a stupid question.....
Are there any differences in a 7.3L diesel Long block from the 95 to 2003's? What I am wanting to do is rebuild a 7.3 to put in my truck. I have a 97 7.3 powerstroke engine that I can rebuild, butwant to make sure that my intake, turbo, accessories and exhaust, etc will all fit. ![]()
bump
you can use that block to begin your rebuild , there are some differences in some of the components, i would make sure i used the exterior components from the original engine to make it all work correctly , front engine cover , oil pan, hpop, fuel filter housing etc.
thank you for your info. I have the early 99 7.3, would you upgrade the HPOP to a 17 degree while doing this rebuild, and is there a lot of electrical (Computer) changing that has to be done with this setup?
nothing electrical willchange , bolts right in
i would go with the 17 degree hpop at the very least. the adrenaline pump is suppose to be a good upgrade even with stock injectors.
thanks all for the great info
