does a bad injector do damage to engine? - Ford Powerstroke Diesel Forum
Old 03-01-2010, 03:13 PM
Like the title says, does a failed injector do damage to that cylinder? If one of the cylinders has ailed a contribution test, and its been ran that way for a while, would that do damage to the piston, rings or cylinder wall?
Would it not do anything?
thx
Old 03-06-2010, 07:00 PM
Bump I got #3 and #8 I gotta replace loking for the same answer
Old 03-06-2010, 07:06 PM
no chance you put a gray cps in your truck did you? The
f7tz-12k073-b part number?
theres some info on phantom codes when you get 3 and 8
I dont think thats a 95 truck issue but i dont know??
Old 03-06-2010, 07:15 PM
you should not see any real damage from a lack of fuel injection on a cylinder, that I know of.
Old 03-06-2010, 10:34 PM
you shouldnt see any damage but a huge loss of power though
Old 03-07-2010, 04:01 AM
not on the 95 I sold it and just bought an 02 off of my company that we just went bankrupt and out of business
Old 03-08-2010, 01:00 PM
if you have a bad injector, replace it (or better yet, them all). If one is not working right the truck will not run right and if its injecting a stream of fuel rather then a mist you are asking for issues.
Old 03-08-2010, 06:11 PM
a damaged injecor can cause uneven spray resulting in burned areas on the cylinder head. a friend of mine had a to have motor replaced for it. it would be wise to getting it fixed!
Old 03-09-2010, 01:17 AM
I did replace the injector, but did not do any compression tests. I think theres a week one in there but not bad enough to fail the buzz or cct test. I think i am going to get the idm redone at beans for 100 bucks to put out the 140 volts
Old 03-09-2010, 01:20 AM
This can happen when a injector sticks open
