02 cold exhaust - Ford Powerstroke Diesel Forum
Old 02-28-2010, 06:13 PM
02 cold exhaust
I have a few questions about a 02 7.3 that i have,i'm curios if any one out there has ever had this issue,at start up the driver side exhaust is cold and passenger side is hot,wandering if hpop is bad?
Old 03-01-2010, 07:14 AM
My first thought would be the Under Valve Cover Harness (UVCH) plug that is prone to unplugging. Good news is, the drivers side is the easy side to check!
http://www.gbreman.com/docs/techbull...eplacement.pdf
Old 03-02-2010, 03:26 PM
thanks,i installed a new one last time i was in there but i will check it over.
Old 03-03-2010, 08:21 PM
i might not have listed my thread correctly ,the driver side exhaust is always hot on number 8 and cold on 2,4,6 until you get it hot or drive it then they all get hot which it was already doing before i changed out 2,4,6 injectors for new ones , which were only 3 months old ,and when i put them in all good until week later let sit over night and now at start up pipe cold again and no power for awhile.anyone ever had this issue before ?
Old 03-04-2010, 03:52 PM
Does any one have this problem with there 7.3,or have had this problem in the past?
Old 03-05-2010, 03:27 AM
Powerstroke Junkie
Time for a buzz test when cold!!
Old 03-05-2010, 07:41 PM
So you think those injectors could be stuck closed cold,I went ahead and changed out all 3 that didn't have oil coming out about 4 weeks ago because it was hard to start and when i did it cranked right up with oil coming out of all of them then about a week later and only after sitting over night cold exhaust again,its funny that those 3 are doing the exact same thing, the truck runs really good after you go 3 miles but before that barely moves then comes alive ,but at least it starts.
Old 03-05-2010, 07:45 PM
get ahold of an ae unit and run buzz, contribution tests, etc.
Old 03-05-2010, 07:58 PM
so only do test when its cold right?
Old 03-05-2010, 07:59 PM
i checked all 8 when it was in bad shape but when it was hot they all checked out good.
