Noise from turbo?? - Ford Powerstroke Diesel Forum
Old 04-16-2007, 09:37 AM
Noise from turbo??
I've tried to read everything I can about wastegates and the exhuast backpressure sensor. When I first start my turck up when it's cold outside(under 30 degrees) There is a whooshing sound from the turbo area. It will come and go with the as you give it fuel. You can hear it at idle and when it levels out on the road.
Thanks
Tim
Old 04-16-2007, 09:44 AM
Thanks
Tim
thats your exhaust backpressure valve.....thats normal operation.....
Old 04-16-2007, 10:00 AM
I have had my truck for 3 years and never heard that until the last month or so. It doesn't do it all the time either?
Old 04-16-2007, 10:13 AM
it should do it whenever your truck is cold, like below the C mark
Old 04-16-2007, 10:18 AM
this is the first time I have ever heard this noise, it is a continous noise unless I give it fuel, and then it come back when the motor levels off at any speed
Old 04-16-2007, 10:20 AM
it only does it under certain conditions, engine oil temp has to be below 32 degrees if i remember off of the top of my head correctly
Old 04-16-2007, 10:25 AM
That would be right for the temp, but should it be a continous noise?
Old 04-16-2007, 10:26 AM
yes...at idle untill engine oil temp reaches whatever the computer turns it off at, its used to create and exhaust restriction to warm the motor up faster...
Old 04-16-2007, 10:31 AM
okay, I trust you, but I just can't remember hearing this before.
I did get a wastegate not detected code about a week ago, but it's not shown it since, so I didn't know if the problems were connected.
