Replacement Mirror ?????? - Ford Powerstroke Diesel Forum
Old 02-26-2010, 04:58 PM
I just bought a replacement mirror for my F350 for one that was busted. It is a power mirror only (tow style), which is what came on my truck stock. I got it pulled off except I could not get the power cable to come up out of the door to unplug the old one. Is there any advice that anyone can give me on this.
Old 02-26-2010, 05:18 PM
Sure,just take your door panel off,you already have inside mirror bolt cover off,now just take a mini screwdriver and pop up door switch panel that has pw,dl and pm's on it.Next remove bolt under panel just removed,take out light cover towards back of door and take out that bolt,and panel will slide up and come off-but take out int.light where cover was removed.Peel back wind cover and you'll see the plug for mirror-easy to do !
Old 02-26-2010, 05:28 PM
Ok cool thanks man. I did take the panel off earlier tonight but it was getting too dark for me to see what was under it so I just put it back together for tonight. I will take a look at it in the morning. Thanks
Old 02-26-2010, 07:57 PM
Glad to help, no problem at all.
