key cylinder removal needed help asap - Ford Powerstroke Diesel Forum
Old 02-25-2010, 10:02 AM
I tookmy column apart and removed the wheel to get to the clock spring. I took all that apart. I am going to ford to get another. My issue is, in order to put back one of the wires it connects to the area where the key cylinder is.
I cant get the plastic bezel around the column out of ther way til i remove the cylinder. I have to put this wire back in while being careful. I cant get the cylinder out.
please let me know how to'
thgx
Old 02-25-2010, 10:06 AM
I'm not exactly sure what your trying to do but if your trying to get the lock cylinder out there is a little hole on the bottom of the column under the lock cylinder that you have to put a pen or something in and push in with the key in the acc position I think. It'll pull right out then.
Old 02-25-2010, 02:30 PM
thx that was what i needed. I pulled the steering wheel off, due to the airbag light code 32. I replaced the clock switch. fixed it.
