Fuel leak-filter drain valve - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-24-2010, 06:34 PM Thread Starter
CutterN55's Avatar
What's the scoop on the leaky drain valve? I guess it's pretty common? The last two days I've done well at marking my territory. Also, seems it's leaking at the plug next to the drain valve. What's best course of action and where can I get the best parts for cheap?
Tow pig
01 Excursion 7.3L with some goodies.
CutterN55 is offline
post #2 of 6 Old 02-24-2010, 07:16 PM
Replacement O-rings for Ford Diesel Engines
call bob and hell set you up with all the parts you need great prices
corwin132 is offline
post #3 of 6 Old 02-24-2010, 08:58 PM
HOUTX01X's Avatar
Quoted: 4 Post(s)
http://www.dieselorings.com/docs/fueldrain.pdf
'11 F250 KR
XRT Pro, H&S SX-E turbo kit, NoLimit intake/intercooler
OUO bars/blocks
-EGR,CCV,1993pf
Leveled w/ 35 atII
HOUTX01X is offline
post #4 of 6 Old 02-25-2010, 12:08 PM
tubular031's Avatar
I just did this on my truck not too long ago. Its a simple fix. I have big hands so working on the bowl was fun. Dieselorings is the place to go! order the whole bowl kit.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #5 of 6 Old 02-25-2010, 12:23 PM
C-5 & C-17 E&E Specialist
AhrmanHammer's Avatar
I just did mine a couple weeks ago. I got the kit from dieselorings. Great seals, there military spec parts. It's an easy job, but the location is a pain to get to... no matter the size of your hands. Good Luck...
2000 F250 SC/LB Lariat 4x4 PowerStroke
DIY Intake, Zoodad, and Stright Piped... More to come eventually
2003 Triumph TT600
Summer Play Toy, 15/49 Sprocket Swap w/ 520 Conversion
AhrmanHammer is offline
post #6 of 6 Old 02-25-2010, 02:29 PM Thread Starter
CutterN55's Avatar
Roger that. Thanks guys.
**** called Bob, he was very helpful. Kit is on the way. Also I appreciate the above PDF. You guys rock.
Tow pig
