fog light wiring/ fog lights
I have a 2000 250 xlt. Dose not have fog lights of it and i do not have the fog light head light switch, Not worried about that at all. I want to get ahold of some fog lights. Whats a decent price?? From what i see most of them come with the Bracket bulb and houseing. Thats it. Which it fine i can come up with some wiring. I was going to tie them into my running lights so when my running lights are on they would be on. What kind of connections are on the back of them i cant seem to find pics. Mainly so i can figure out how im going to wire them before i get some. Any thoughts would be awesome.
Thanks guys |
Bump. Would like to know also.
ill post pics what i did to make mine work. i just added em a few weeks ago.
Easy..use your park light as a signal wire to turn a relay on which gives the fogs the ability to turn on or off...or use some kind of ignition source.. ( power when key on only) only reason i say that is so you dont accidentally leave them on... it wont be hard, get a couple pig tails from the auto store too for the lights, use wire loom and some connectors, a nice rocker switch and make sure you fuse the power line and away you go..OR if you really want to you can buy pre made harness kits, you can use a PIAA kit or a lightforce kit,KC kit they all will come with everything youll need, i used a piaa wiring kit for my seconday lights.
Yeah. Im probably going to wire them into the parking lights so they turn on and off with the parking lights. They should be here later this week
