Cuts out and dies
My 99 F250 is cutting out while driving at varying RPMs. It will be running great and then cut out with the tach dropping and then going back to normal. It will also just die but then will start right back up. I recently did a little maint and changed the fuel filter and the cam sensor. Any thought on what to check??
man if its not the cps or the fuel filter.. uhm ICP?
what cam sensor did you put on? if it is a gray one from ford they can be bad right outta the package
+1 on the CPS. Get the International part, dark dark grey with purple O ring, part number ends with C91. I just put one in today, and I was surprized how the idle smoothed out.
