Water temp not working on scan gageII
I have a scan gage II and the water temp is not working it shows -40 all the time. On my other cars it works. All other things show up like trans temp, map, speed, lod, etc. I was wondering if I had a bad coolant temp sensor or something? The dummy gage says just below half once its warmed up. heat works well warms up pretty fast. So would I get a check engine light if the coolant temp sensor was bad?
Thanks Duane |
Any Ideas?
I am pretty sure the 7.3 does not have a coolant temp probe that the ECM reads. the 6.0 does. I monitor engine oil temp on my edge monitor since I dont get an option for coolant.
ok something new to know about these things. I will have to get the code for engine oil temp on my scan gage
Thanks |
I think EOT is more useful anyway. I can have the coolant at 170 deg and the oil tem is just hardly over 135 to 140. I dont consider my truck as up to temp till I see 165 EOT.
Mine says -40 all the time too. I assume the PCM must know the coolant temp but I have not seen a code for it.
The scangauge site has a whole section for 7.3 diesels and has codes for injector pressure, pulse width, engine oil temp, and more. There is also a handy plug near the thermostat if you ever wanted to install a real water temp gauge. Many people use this port for their coolant filters. |
I have the same gauge in my 2000 and it doesn't read water temp. Not sure what year yours is if you give them a call they are very helpfull and with email you all the xgauge codes for the 7.3L.
