Carrier Bear question - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-23-2010, 07:25 AM Thread Starter
I'm going to change the carrier bearing this weekend...once you disconnect the rear portion of the driveshaft to gain access to the big nutso you can slide the yoke piece off..Is it okay to leave it in park to prevent the driveshaft from spinning while using a breaker bar to loosen the nut? Im guessing the parking pawl can handlethe force since when you put the truck in park the weight of the truck is on it?
makaveli200369 is offline
post #2 of 13 Old 02-23-2010, 07:33 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Once you remove the drive shaft, it will roll wheteher it is in park or not because the shaft is removed and there is nothing to keep the rear diff. from turning. Are you replacing the carrier bearing that mounts to the cross member that supports the drive shaft?
dhanna6powerstroke is offline
post #3 of 13 Old 02-23-2010, 08:44 AM
I think the OP wants to use the parking pawl in the trans to resist the torque of him removing a big nut on the driveshaft. Sure would stink if you broke it. Would an impact gun be better?
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
post #4 of 13 Old 02-23-2010, 09:08 AM Thread Starter
That's right. I'm going to use an impact but I'm not sure the one I have is powerful enough to bust that free...if worse came to worse I would use the parking pawl to resist it. I'm pretty sure the pawl is strong...if you parked the truck on a hill without using the parking brake I would guess it is a pretty big load on the pawl..probably more then I am putting on it?
post #5 of 13 Old 02-23-2010, 09:18 AM
symbols's Avatar
Well I have a 1/2" IR impact and that was like me trying to turn it by hand. I ended up breaking (2) 1/2" break over bars and my vice trying to get that nut off. I ended up buying a new vise and some 3/4" sockets and breakover bar to get it off. I figure if I could break all that then I could have broken the parking pawl as well
Jason
"Using a thug's murderous rampage to call for gun control is like using Barack's reckless spending to call for higher taxes."
--Michael Berry, American philosophizer & Talk Radio Czar, 1970-?
symbols is offline
post #6 of 13 Old 02-23-2010, 09:49 AM
Fred Swanson's Avatar
My 2000 F-250 4x4 PSD didn't have any type of a nut retaining the yoke, I dropped the front of the driveshaft only and simply pulled the slip joint with the front section of the driveshaft and the carrier bearing with it, it is important to mark the driveshaft sections to reassemble exactly as it was taken apart...Fred
1995 PSD F-350 Crew Cab Dually....Sold
2000 PSD Crew Cab F-250 4x4
285 Geolanders
EBP sensor and tube clean
Badwin air filter #PA2818
Replaced carrier beariing
Replaced water pump
Repalced ICP and CPS
Straight Pipe
Gauges and A pillar pod
Superchips Flashpaq #1805
Foil Delete Mod
Replaced Glow Plugs ZD11's
Fred Swanson is offline
post #7 of 13 Old 02-23-2010, 12:24 PM Thread Starter
Thanks for the heads up..Maybe I will have to remove the damn thing...
post #8 of 13 Old 02-23-2010, 04:36 PM
Mod Newbie
Quoted: 20 Post(s)
I was confused for a bit!
post #9 of 13 Old 02-24-2010, 10:05 AM
symbols's Avatar
For some people it comes off with just an impact but if your luck is like mine your going to have to take it off
Jason
symbols is offline
post #10 of 13 Old 02-24-2010, 11:08 AM Thread Starter
haha...is the nut reverse threaded? How many lbs of torque do you have to tighten it back at?
