Tire pressure - Ford Powerstroke Diesel Forum
Old 02-22-2010, 10:47 PM
Tire pressure
Real quick question. My truck from orevious owner has 305/70/16's on it. Should I put the air pressure back to what factory recommends or not? I think this might be why im only getting 10.5 to 11mpg's. They are Firestone mud tr's. My truck I think says 50psi front and 70psi rear. I might have that backwards but I think im right.
Old 02-22-2010, 11:04 PM
ill say screw the mfg recomendation and run the tires at max or 10psi under max. (depending on the vehicle. the cars are max)
but you might get the center wear on the tread tho
i always run all our cars and trucks at or near the max to get the max life from the tire. plus rides better.
Old 02-23-2010, 03:55 AM
If it helps..I'm running Mickey Thompson Baja ATZ's at 4 lbs below tire max pressure. I travel a lot and seem to get real good milage and no unusual wear...they are and a half old at htis point.
Old 02-23-2010, 05:04 AM
i run mine all at 55psi, more then that i hate the ride, ive had no wearing issues at 55psi, i pump them up when towing..
