need a new clutch - Ford Powerstroke Diesel Forum
Old 02-22-2010, 04:39 PM
need a new clutch
so my clutch has been slipping pretty bad. so its time for a new one. but which one. i used my truck for work and play. its got a chip and i don't plan on going with a turbo or injectors unless they blow up.
Old 02-22-2010, 04:54 PM
if u buy one buy an aftermarket one any brand is fine really. the aftermarket ones are very easy to press the pedal with but ford clutches have less fingers making it very difficult to push the pedal
Old 02-22-2010, 05:05 PM
i just had the same issues, and replaced mine with a valair organic clutch. if you tow very heavy loads, get a ceramic clutch, but if yiu tow lighter loads, get an organic clutch for better daily driving. but make sure you upgrade to a single mass flywheel. My clutch is rated for 450 horse and 900 torque. pm me if your interested ill send you a link to where i got mine for a great deal.
Old 02-22-2010, 05:08 PM
I put a LUK clutch in. No issues. It has an easy stock-like pedal feel.
Old 02-22-2010, 05:14 PM
i pull like 3500 lbs almost daily in the spring summer and fall and occasionally i pull something 8k + like six times per year maybe
Old 02-23-2010, 09:01 AM
what about the flywheel? do i need to order a new flywheel also?
so i called valair just a bit ago and he basically said i have these two options
http://www.valairinc.com/performance/7399-03.html
NMU70241-01
NMU70241-05
he also said i don't need a new flywheel. that the one i have in there now can just be resurfaced.
what do you guys think?
Old 02-23-2010, 06:36 PM
that depends on if you have a single mass flywheel already, if you do, they can be resurfaced. Dual mass flywheels cannot be resurfaced. I wasnt sure what i ahd so i just ordered it.
Old 02-23-2010, 06:38 PM
according to valair its a single mass but idk
Old 02-24-2010, 03:55 AM
Send a message via Yahoo to Big_Stroker
Valair has my vote.
Old 02-24-2010, 09:16 AM
Originally Posted by Big_Stroker View Post
Valair has my vote.
its got mine also. i just cant decide between the two i listed above.
