Rear End Gear Ratio - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-22-2010, 06:58 AM Thread Starter
Rear End Gear Ratio
I just bought a F-350 4wd PSD single wheel rear end and was wondering how to tell what gears i have in the rear end and what is "typical" if it is hard for a novice to figure out?
thanks,
tate
tatemcc is offline
post #2 of 4 Old 02-22-2010, 07:28 AM
Fred Swanson's Avatar
There should be a tag on the rearend cover bolts, the tag will tell you what gear ratio your truck has unless someone changed them.....my 2000 super-duty has two tags, one on the drivers side of the rear cover bolts says to use synthetic the tag on the passenger side calls out the ratio and if it's limited slip or not....Fred
1995 PSD F-350 Crew Cab Dually....Sold
2000 PSD Crew Cab F-250 4x4
285 Geolanders
EBP sensor and tube clean
Badwin air filter #PA2818
Replaced carrier beariing
Replaced water pump
Repalced ICP and CPS
Straight Pipe
Gauges and A pillar pod
Superchips Flashpaq #1805
Foil Delete Mod
Replaced Glow Plugs ZD11's
Fred Swanson is offline
post #3 of 4 Old 02-22-2010, 07:29 AM
Ratios should be either a 3:73 or 4:11....being a F-350 it may tend to be the 4:11 ratio....Fred
285 Geolanders
Replaced water pump
Straight Pipe
Foil Delete Mod
post #4 of 4 Old 02-22-2010, 03:02 PM
countryraised's Avatar
F-350 with SRW will probably be a 3.73, on F250's you could get 4.11 srw but on 350's you had to go to a DRW to get a 4.11.
Vince
John Deere product developement
FOR SALE '99F350 2008 F350 mini maxx'd
countryraised is offline
