dptuner from riffraff diesel - Ford Powerstroke Diesel Forum
post #1 of 18 Old 02-21-2010, 11:02 AM Thread Starter
Hey guys, I am thinking about a tuner and keeping it simple for now.
Hows the dp tuner from riffraff? Its an f5 chip and its 199$ plus tunes.
Not looking for a lot of tunes. may just get 2 of them. I want the tranny to work more efficient and to get more response from the pedal.
His tunes are 45 each.One tow tune 60hp and econonmy 80hp.
thats really all i want for now
any thoughts
2008 6.4 f250 lariat 4wd
melmount is offline
post #2 of 18 Old 02-21-2010, 01:11 PM
AFBLUE's Avatar
I dont know that seller, but why dont you just go right to the source? DP-Tuner
06 CCSB Lariat 102K
Factory 20s w/ Nitto Trail Grappler 35X12.5X20
Vegistroke 75,000 miles
2.5" Readylift Level
ARP Head Studs
EGR delete
Swamps 58V FICM
Isspro Gauges, EGT, Boost, Trans.
20ft of 4" straight pipe!!
SCT X3 BAMF Innovative Xtreme Race
AFBLUE is offline
post #3 of 18 Old 02-21-2010, 04:55 PM
IBEW Journeyman Lineman
PolarBear's Avatar
If you are only looking for a couple of tunes and wanting to save $$$. Check out Power Hungry Performance at gopowerhungry.com. They are also known as PHP around here and are highly recommended.
2012 F350 XLT CCLB 4x4 6.7
PolarBear is offline
post #4 of 18 Old 02-21-2010, 05:13 PM Thread Starter
thanks polar bear,
just checked them out. I will check them out during business hours again tomorrow.
The dp tuner with one tune is 245 and 290 for two. I dont know if it comes with a switch for that? If 2 tunes it will have to have one. The php does.
melmount is offline
post #5 of 18 Old 02-21-2010, 08:39 PM
99towbeast's Avatar
I just installed my DP F5 chip today and WOW does it wake up your truck!! You will not be disappointed with Jody's tunes from DP. the shift points are unreal, you just stay in the powerband the whole time, no lugging between shifts.
99' F350, 4X4 dually
MFG flatbed with toolboxes
10000 lb Warn Winch
BFG all-terrains
ISSPRO gauge (tranny, boost, pyro)
ISSPRO turbo temp monitor
AFE Stage II intake
5" straight pipe exhaust
DP TUNER F5 chip (no start, stock, 80 tow, 60 tow, and 80 econo)
Zoodad mod
second tranny cooler installed in series behind grille
cb radio
HID headlight conversion
99towbeast is offline
post #6 of 18 Old 02-22-2010, 04:47 AM Thread Starter
tow beast, did you use the tunes from the drop down box when you bought the f5 chip? did you have something custom done?
melmount is offline
post #7 of 18 Old 02-22-2010, 09:25 AM
99towbeast's Avatar
Yeah, I just chose the drop down menu tunes for my F5 chip. Unless you have aftermarket injectors, or big oil, I think Jody's drop down tunes are spot on and you don't really need the custom tunes. Just tell him what you have done to your truck and the family code on your PCM. Just take out your PCM from under your dash and look at the barcode sticker. the very top digits is your family code. For examply, mine was
XLE8.
10000 lb Warn Winch
BFG all-terrains
AFE Stage II intake
Zoodad mod
cb radio
post #8 of 18 Old 02-22-2010, 03:11 PM
layson's Avatar
Quoted: 82 Post(s)
I have gotten a few things from Riffraff Diesel. He is a great guy to work with!!!!
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #9 of 18 Old 02-22-2010, 03:24 PM Thread Starter
He has been cool to me too! I emailed him yesterday, and called today, cant get a hold of him yet??
melmount is offline
post #10 of 18 Old 02-22-2010, 03:29 PM
storkerlovr's Avatar
good luck getting PHP tunes on a DP chip. a TS chip can be tuned by anybody, DP....only DP
95 reg cab 4X4 STROKER
< trade for 5 speed???
new E40D
Autometer gauges
Gearhead tunes
EBP actuator deleted but not gutted
Push button start
TC lock up switch
DIY with 6637
3.5in DP
5in MBRP
315/75/16 M/T ATZ
3:55
smoked lights
herculiner
10inch PRO JL
20%tint
screw all this I just want a 6.4!!!!!!!!!!!!!!
wish list;
5 speed swap
stage 2 injectors
D66
"there may be snow on the mountain but that doesnt mean theirs no fire downstairs
storkerlovr is offline
