STACK HELP PLEASE!!! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-20-2010, 05:48 AM Thread Starter
Nally7.3Powerstroke's Avatar
I am installing my stack today and I need to see how you all mounted your stacks and ran exhaust and just the whole setup if you have any pics of it. I could really use anyones help so I do this right.
Nally7.3Powerstroke is offline
post #2 of 6 Old 02-20-2010, 05:56 AM
dsljnky's Avatar
Send a message via AIM to dsljnky
sturdyest way i have seen is a plate welded onto the stack and mount it to the bed also put a matching plate under it... what afriend did on his cummins
02 lb7
97 7.3
dsljnky is offline
post #3 of 6 Old 02-20-2010, 06:03 AM
Let's go B's!!!!
Southpaw's Avatar
Feedback Score: 5 reviews
What size is your stack at the bottom? does it reduce or is it 7" straight?
Chris
2002 Crew Cab Long Bed
4" BDS, 35x13.50 Cooper STT on 20x10 Black Rockstars, and other stuff.....310,000 miles and counting...
2 Thessalonians 3 v.6-15
Southpaw is offline
post #4 of 6 Old 02-20-2010, 06:10 AM
BIGBILL105 45's Avatar
My stack is a 6 inch that reduces down to a 5 and what I did is attached an elbow onto the bottom of the stack, ran flex pipe to the old exhaust. And to keep the stack from moving or anything, I bought a 6 inch stack clamp and screwed it into the bed. Held up really well.
PM ME FOR VINYL DECALS!
SOLD!!!!!
ARP head studs
4 inch down pipe
5 inch straight pipe
ts 6 pos chip
foil delete w/ polished IC pipes
ugly step delete
2% tint
black lariat rims
35 inch Pro Comp Xterrains
7 inch in dash dvd player
remote starter
16.265
BIGBILL105 45 is offline
post #5 of 6 Old 02-20-2010, 06:12 AM
armymp15's Avatar
I am about to do a dual 7" stack install my self. I know there are a couple videos on youtube of installs. I think they are cummins mostly buy still shows a few tricks and a good over view. Good luck
1999.5 F250
Facebook: James Hollis
6 SPEED
Tymar DIY Intake
Pyro/Boost Gauges
TS 6 pos chip (can tunes)
7" GRAND ROCK dual mitre cut stacks
Sky Manufacturing Leveling Kit
F350 Blocks
315/75/16 BFG MT
armymp15 is offline
post #6 of 6 Old 02-20-2010, 07:19 AM Thread Starter
My stack is a 7 inch that reduces down into a 5 inch. But I bought a 5 to 4 inch adapter with it because my old exhaust is a 4 inch straight pipe. I bought some flex pipe, a 90 degree angle pipe, and I will have some extra 4 inch pipe when I cut my exhaust off under the bed.
