Stock fuel pump relay location. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-20-2010, 03:53 AM Thread Starter
simone0414's Avatar
I assume it is in the fuse block under the hood but I have looked at the diagram in my owners manual & it does not list it or in the diagram for the fuse block in the cab. It must be there but under a different name.
I tried searching for this but for some reason the search function does not work for me. Not sure if its this site or my computer.
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #2 of 2 Old 02-20-2010, 05:40 AM
Quoted: 172 Post(s)
Feedback Score: 3 reviews
Look under the radio, behind the cup holder in the center of the dash. I think your '01 has it there....
If not, I believe the next place they put them was to incorporate into it the fuse panel (the '02 &3s for sure)
NoRalPh is offline
