isspro trans temp wrong or ?
hi im wondering if i have a bad gauge or sending unit i have a the isspro ev2 gauges they all work but the trans seems to be off it takes 20 mins of driving to show a reading above 100 degrees and when it does it only goes to 120degrees at the most towing is this normal or is some thing wrong gauge is 2 weeks old and its a 99 f350
Whats the outside Temps? My tranny takes a bit to register a temp also when it is cold.
thats the same thing my tranny gauge does. when its real cold (-30F), it doesn't even tell me anything.
all depends on how cold it is..
makes sense its been around 25 degrees during the day and at night and morning around 5 to -10 im up in minnesota could this tmp reading be ok then and it only gets up to 120 degrees seems kinda low to me im new to this
the trany temp gets to 120 that is
The temp outside plays a huge difference in the trans temp. The colder it is the cooler the trans will run and the longer it will take the temp to registrar
you are OK I'm in Iowa I see the same thing, usually tranny temp is close to outside temp +100.
