Boost readings - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-19-2010, 02:08 PM Thread Starter
Boost readings
I have a 02 f250 with the 7.3 and the only thing I have done is.. 4in turbo back exhuast.. what should be my boost range..... cause i think i have a leak somewhere
Fleet2904 is offline
post #2 of 11 Old 02-19-2010, 02:22 PM
OregonStroker's Avatar
19-20 before a check engine light pops on. it will be hard to hit those numbers too. realistic numbers w/out a chip will be somewhere in the ball park of 15-18ish
Built engine, rods, pushrods, cam, springs. Meth, turbo, injectors, fuel system, oil system. 3 disk billet, billet shafts built trans, 6.0 IC, exhaust, intake. Latter bars, gears, system, tint, HIDs. You know the typical stuff to make a 7.3 get out of its own way...
dont brake.
OregonStroker is offline
post #3 of 11 Old 02-19-2010, 02:32 PM
Rohan's Avatar
I've pushed 27psi after IC with chip on 80hp tune. don't know about before chip tho
2003 F250 FX4 7.3L CC/SB Lariat
S&B Intake, DP Tuner F5 60T/60E/80E
Wicked Wheel, Autometer Gauges
Muffler Delete, AIH Delete, foil delete
BrightBox + FogLights mod
HPO X-Over
Rohan is offline
post #4 of 11 Old 02-19-2010, 02:33 PM Thread Starter
today i had some gauges installed.. and when me and the diesel mech.. went for a ride... all i can get is 9psi..... so well started to look at everything... the line to the gauge was good no kinks or anything of that nature.. he ran out of time to figure out why... and we didnt dig to deep into it.. any ideas
post #5 of 11 Old 02-19-2010, 02:51 PM
GoldieStroker944's Avatar
i can get about 22 but thats wot on my 75hp setting but i think i have a leak as well
2003 7.3L
Crew Cab Short box
Lariat
Cowl (functional)hood
315/75-16 wild coutry A/T's
Hypertech power programmer 3
T.S 6pos
stock,high idle,50,75,100,140
AFE stage 1
Foil delete
MBRP Cool Duals 6" tips
Sirius sat radio
GoldieStroker944 is offline
post #6 of 11 Old 02-19-2010, 03:13 PM
F250 Fever's Avatar
Send a message via Yahoo to F250 Fever
alot of people have told me if hhave low boost always check your boots and up pipes those are the usually number one problems with boost leaks.
2000 7.3 F250 FX4 ext cab short box
Cobalt Pillar Trip pod gauges, trans temp, boost, pyro
4in down pipe to a 5in tip
KnN intake
Tuned by PHP
Banks big head waste gate
6in Pro comp lift
Mag hytec tranny pan
Diablo predator programmer (used for pulling codes)
Foil delete
ATS Turbo housing
Halo projector headlights
BUILT TRANNIE-
Euro taillights
Radar detector
Window tinted 20%
F250 Fever is offline
post #7 of 11 Old 02-19-2010, 04:11 PM
ya 9 psi is too low. I would say for sure a boot is loose. if your egts are high then for sure its a boot.
dont brake.
post #8 of 11 Old 02-19-2010, 04:16 PM
Mikey's250's Avatar
Exact same thing happened to me. Search boost leak detected on google and make you or buy you one. I replaced my intercooler boots and got up from 9 to about 18 now I gotta check the up pipes
Mikey's250 is offline
post #9 of 11 Old 02-19-2010, 04:48 PM Thread Starter
what do i need to check on the up pipe
post #10 of 11 Old 02-19-2010, 05:09 PM
Fred Swanson's Avatar
Visually look for any soot, =exhaust leaks around the up-pipe doughnut gaskets...
1995 PSD F-350 Crew Cab Dually....Sold
2000 PSD Crew Cab F-250 4x4
285 Geolanders
EBP sensor and tube clean
Badwin air filter #PA2818
Replaced carrier beariing
Replaced water pump
Repalced ICP and CPS
Straight Pipe
Gauges and A pillar pod
Superchips Flashpaq #1805
Foil Delete Mod
Replaced Glow Plugs ZD11's
Fred Swanson is offline
