99 Dies after 10 seconds
I have a 99 that starts fine, but after about 10 seconds it shuts down and will not restart. Only crank. Wait about an hour and it will start. Any ideas?
Crank Postition Sensor?
Try Replacing The Cps. Sometimes It Will Have Those Symptons
Ive heard that is a good idea to have a spare one of those in the truck because they go out a lot.
is the oil full and in good condition , sounds to me like you might be losing high pressure oil because you run the reservoir dry and then base engine oil pump doesnt refill, next time you crank it and it shuts off , check and see if high pressure oil reservoir is empty whe its not starting, also get codes puled
Treat me like a total idiot and please explain how to check the high pressure oil res. I am a newbie to diesels.
Check out this thread. Theres a good description on where and how to check the oil in your hpop.
http://www.powerstroke.org/forum/7-3...=checking+hpop |
in front of the fuel filter housing where you change the filter , that housing there is the reservoir that feeds the high pressure oil pump, in that housing there is a allen head plug , if you pull that plug out you should see oil, it has to be at least a half inch from the top or engine will not run, when your engine quits , pull that plug and see if any oil is in that reservoir
Thanks guys. I will check it as soon as I get home.
