Tires - Ford Powerstroke Diesel Forum
Old 04-11-2007, 07:58 PM
Tires
Does anyone know wat is the biggest tire you can go with on a a NON lifted super duty it is a 99 so it does have front leaf springs. I was wondering if anyone knows where to get some resonable priced tires that have kindof some aggresive tread but are load range d the minimum thanks
Old 04-11-2007, 08:08 PM
The Fat Mod
Pretty much anything you find will be in load range D, if you can find Es, that would be better. I have run 305/75/16s in a stocker with no problems. If you get a leveling kit for the front, I am sure you could do at least 315s.
Old 04-11-2007, 08:10 PM
I ran 305/75 16 on mine with no lift. I have 315/75 16 now but I had to do 2 1/2 level kit in front and the left side rubs slightly on hard left turn but not enough to make want to lift it more.
Old 04-16-2007, 03:02 PM
Feedback Score: 5 reviews
I have 275/65R20's on my truck with no rubbing. That size is 34" tall. No lift or leveling kit either. Hope that helps
Old 04-16-2007, 03:09 PM
duct tape & zip ties
33 inch tire is about the max you can go with no problems. You might be able to go taller but not wide. 305x75R16 is equal to 33x12.50R16, I run 285x75R16 on my truck which are equal to 33x11.50R16. I prefer the 285 over the 305 because of price. Plus in snow the narrow tire works better. Plus the 285 is still wide enough for the mud I go through so I don't get stuck.
Old 04-18-2007, 08:49 PM
im also trying to decide what size tire i should go with...i have a 99 with the stock 8 or 9 hole rims. i love those rims. i also have a leveling kit.
im wondering, can i run the 33x12.5r16 (305x75r16) on the stock rim?
does it look kinda cheesy?
Old 04-18-2007, 08:54 PM
PIPE HITTER
33's should be just fine, I woudn't think it would look bad at all.....
Old 04-18-2007, 09:00 PM
any reason to choose the 305x75r16 over the 33x12.5r16 eventhough they are equal?
thank you for the quick reply
Old 04-18-2007, 09:03 PM
I used to run 9.00x16's on my 99 which are 36" tall and 9 wide. I didnt have any lift but the truck did have X code springs and some fender trimming. I also ran 37x12.5x16.5's on 16.5x9.75 rims with more fender trimming.
Old 04-18-2007, 09:28 PM
PIPE HITTER
can't see one reason or another, except in general, more agressive off road tires are in the 33XxxXxx and more "streetable" for lack of a better term, all terrain and just plain ole' street tires are found in the 305/xx/xx sizes.
