Oil report! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-12-2010, 03:15 PM Thread Starter
O.I.F. Combat Vet 11B
Oil report!
Well, I got my report back from blackstone and very happy to say the lest. I didn't put how many miles the engine had and they said it looked to a "spring chicken". Said it had very low wear!! So I am very happy considering I have 226,xxx on the engine. Just wish I could fig out my it smokes like a freight train on cold starts.
2000 f250 crew cab 4x4 6sp manual, Jim Rosewood 238/100 hybrids, gtp 38r, srp1.1 hpop, DP-Tuner! Driven diesel fuel sys!
269,xxx and counting!!
ju015dd is offline
post #2 of 9 Old 02-12-2010, 07:25 PM
02PUFFER's Avatar
Rock and roll! Thats really good to hear.
I had problems with mine smoking and consuming oil as well, it turned out to be a coked up oil ring on the backside of the turbo. Ran great otherwise, just used a quart or two more per oil change and smoked at cold starts.
Craig
2002 F-250 7.3L 4x4 SC/LB Lariet
02PUFFER is offline
post #3 of 9 Old 02-12-2010, 07:41 PM
Diescipel's Avatar
Hey man, congrats-- I just did mine too and got glowing results for a 202k mile 7.3.
Could you post yours so I can compare? I could post mine again on this thread too. EDIT here's mine attached.
Maybe we could create a sticky of 7.3 oil analysis results for everybody to compare and see what's going on with their engines, but then again the Blackstone boys kinda do that for ya.
Late '99 F350 4x4 XLT Reg Cab with ZF6S & Factory LSD rear, nearly bone stock, 200k+ mi
KCM HPx Xover
Diescipel is offline
post #4 of 9 Old 02-12-2010, 08:21 PM Thread Starter
here is mine
ju015dd is offline
post #5 of 9 Old 02-12-2010, 08:29 PM
Diescipel's Avatar
Originally Posted by ju015dd View Post
here is mine
We are looking good!
KCM HPx Xover
post #6 of 9 Old 02-12-2010, 08:57 PM Thread Starter
where is this oil ring you had stopped up on your turbo/?
ju015dd is offline
post #7 of 9 Old 02-12-2010, 09:10 PM
Former OBSer
oasis04's Avatar
Quoted: 9 Post(s)
LOL, Get ready for late night drunk dials.
I would remove your personal data before posting those.
Note: it will not be me calling.
Oh....awesome results.
[/SIGPIC][/SIGPIC]Jeff
Semper Fi!!!!!!!!!!!
'13 F250 Platinum
amp power steps
ez-lynk
GDP tunes
5" straight pipe
deleted
CAI
oasis04 is offline
post #8 of 9 Old 02-13-2010, 05:31 AM
02PUFFER's Avatar
Aw man, I just changed mine, still haven't sent out the sample.
It looks like a tiny piston ring that stops oil from spewing into the exhaust side of the turbo. Its on the shaft itself in the housing
If you look between the left-hand brass bushing and the turbine, there is a little groove that the ring snaps in. Your smoking might caused by something different but my oil analysis comes up great like yours did, it might be the same situation ya know?
Craig
02PUFFER is offline
post #9 of 9 Old 02-13-2010, 06:11 AM
chrispaine's Avatar
How much and how long does it smoke for, I get a little smoke for a minute or two but then it goes away.. was told its normal..
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
