PMR or forged connecting rods in my 2001 - Ford Powerstroke Diesel Forum
Old 02-10-2010, 04:45 PM
I did some searching but could not find the direct answer...
I have a 2001 f250 7.3 DI with a build date of 10/2000, does anyone know what the cutoff is on the forged/PMR connecting rod engines?
Is there anything short of removing the oil pan to find out if it has one or another?
Basically the truck has a HyperTech 3 stage puter' upgrqade, a cold air intake track with a K/N unit, and a 3 1/2 all the way out the back. I am looking at possibly playing with it to add more power, but obviously dont want to push the envelope if it has PMR rods.
thanks!
Old 02-10-2010, 04:47 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
It could be either or honestly
Old 02-10-2010, 04:55 PM
kinda, what I thought by doing search's on the forum...
thanks for the reply
Old 02-10-2010, 04:59 PM
Dieselis' Maximus
Here is an inspection hole.
7.3 Inspection Hole for Powdered Metal Rod Determination
Old 02-10-2010, 05:00 PM
Well whats your serial number on your truck.? You can go by that.
Old 02-10-2010, 05:21 PM
EB020**
is the last of the vin....
does this help?
Old 02-10-2010, 05:25 PM
Originally Posted by driximus View Post
when it warms up around here if all fails, I'll remove the plug and check the rods..
all fingers crossed for forged rods!
Old 02-11-2010, 02:37 PM
Feedback Score: 5 reviews
Here is the engine serial number break down for the forged and powdered connecting rods. Check you engine serial number on the valve cover build sticker or you need to look at the block where the oil cooler is bolted to it .
Start of production thru 1425746 are Forged Rods
1425747 thru 1440712 are Powdered Rods
1446713 thru 1498318 are Forged Rods
1498319 thru final production run are all powdered
Old 02-14-2010, 06:51 AM
"If" your talking about the sticker on the left valve cover, then it's missing, I see where it was but that's about it. I'll have to wait until it gets warmer and I'll check it out.
I appreciate the help....
john
Old 02-14-2010, 06:59 AM
wriott
Guest
Posts: n/a
we dont know if the serial numbers are correct to determine the PMR and forged rod motors... the BEST way is to pull the inespection plug and look
